Β
  1. Jalopiejoe's Avatar
    Can anyone suggest a replacement battery that fits in the original space that lasts much longer than OEM?πŸ‘πŸ˜’
    There are several listed on eBay but if you read the reviews they are no better or junk!
    Sent from my Samsung Galaxy Note 3
    "Size Does Matter!"
    07-05-2014 12:02 PM
  2. zedorda's Avatar
    Without spending alot more you can't get more charge from the same space. Most cell phone batteries are Lithium-polymer and the upgrade is Lithium-ion but it costs around 100 times more by volume. Lithium-ion can have a more dense charge capacity within the same foot print.
    So unless your willing to spend about $100-$200 for the spare battery just get a second of similar quality.
    P.S. There are some exception but only in the range of 10-15% more but still expect them to cost alittle more than the avg. OEM replacement. Andida a Japanese battery company is a good one to check out.
    http://www.andida.hk/en/main.asp
    Jalopiejoe likes this.
    07-05-2014 12:38 PM
  3. atkichr's Avatar
    Here's one I just bought. Had the same kind for my s4. Has all day power never needed a spare
    Attached Thumbnails Extended life aftermarket battery?-screenshot_2014-07-07-17-27-30.jpg Β
    Baby_Doc and Jalopiejoe like this.
    07-07-2014 05:29 PM
  4. Baby_Doc's Avatar
    I guess experience may vary with this cell. I didn't get any longer usage time with this extended cell than with a new OEM cell. BTW, they both weighed in exactly the same, which makes me believe that the claim of 4360 mah for the "extended" cell is exaggerated.
    07-08-2014 09:33 AM
  5. atkichr's Avatar
    I had this at 47% this morning when I left for work. At 32% as of 8:30pm.
    07-08-2014 08:40 PM
  6. jxlee#WN's Avatar
    i'm also looking for one. do not buy the 4500mah ebay black ones. i used to buy the extended one for my htc phones and they were fine. But the other day i pulled htc phone out of storage and the battery was literally swollen twice the size. luckily the battery wasn't in the phone. As for the ones for the note 3, I bought 2x 4500mah, and yes they are junk. Both put together couldn't hold a charge longer than one oem battery.
    Attached Thumbnails Extended life aftermarket battery?-note34500.jpg Β
    07-10-2014 02:05 AM
  7. Jalopiejoe's Avatar
    I just bought an Andida 3200 mAh extended life battery that I am trying right now! I will report back with my findings on it. If it turns out to be a piece of crap, I also bought an Anker 3200 which seems to get good reviews. The Andida has a weird brake-in period.
    You are supposed to run the battery all the way down then charge for 10 hours and do this for 4 cycles, then you are to see a improvement of life over the original battery. (??)
    We'll see! I'll report back.πŸ˜‰πŸ‘Œ
    "Size Does Matter!"
    07-10-2014 08:49 AM
  8. Jalopiejoe's Avatar
    "Size Does Matter!"
    Other than the weird charging ritual, I wanted to talk to someone about the Andida battery and could not find a way to do so.
    I did call Anker and got some questions answered and installed their Anker 3200 mAh battery and am pleased so far by the way it seems to last! πŸ‘πŸ˜Š
    "Size Does Matter!"
    anon8380037 likes this.
    07-12-2014 10:49 AM
  9. Jalopiejoe's Avatar
    I'm happy with my Anker battery so far!
    "Size Does Matter!"
    07-20-2014 03:52 PM
  10. Jalopiejoe's Avatar
    "Size Does Matter!"
    "Size Does Matter!"
    Attached Thumbnails Extended life aftermarket battery?-1405986441568.jpg Β  Extended life aftermarket battery?-1405986482696.jpg Β
    07-21-2014 07:48 PM
  1. Battery issues or bricked. Red light. Help
    Last Post: 02-24-2015, 02:00 AM
  2. s5 uninstalled game app still running and draining battery, help!
    By StardustGalaxy in forum Ask a Question
    Last Post: 09-10-2014, 11:42 PM
  3. Replies: 1
    Last Post: 09-01-2014, 08:44 PM
  4. the battery
    By Zain Daboul in forum HTC One Max
    Last Post: 07-05-2014, 11:58 AM
  5. Battery Life
    Last Post: 07-05-2014, 06:13 AM
