1. jr92897's Avatar
    My phone is about 8 months old and for the last 3 months I've had endless battery problems. It started when (over a two week course) the battery slowly got worse and worse until it wouldn't last any longer than 12 hours on a full charge (and that's with power saving mode).
    I bought a new battery, a genuine samsung battery and it was even worse than the old one, it never lasted more than 10 hours at a push. I then bought a non-genuine 4200mAh which lasted about 12 hours, for a week and then it expanded until the battery cover unclipped and the battery no longer fit in the phone.
    So I bought another battery, a genuine one, and yet again it lasted no more than 12 hours. Just over a week later the battery started leaking! Now I'm on the 5th battery (genuine) and this one has never lasted any more than 3 hours on power saving mode.
    It's got to the point where there is absolutely no point of buying a new battery, and I can't take my phone anywhere as it'll die before I get to the door.
    I bought it new online and online sellers are never helpful when it comes down to warranty.
    What could the problem be? I mean all I can think of that it could be, is the phone.
    Thanks ๐Ÿ˜‘
    07-18-2014 06:36 PM
  2. Relgoshan's Avatar
    Thanks
    Sounds like a bad voltage regulator. And/or firmware problems caused by an OS update. Have you done a factory reset to check this?
    07-18-2014 07:42 PM
  3. jr92897's Avatar
    I have done a factory reset which unfortunately did nothing.
    07-19-2014 04:12 AM
  4. Relgoshan's Avatar
    Then it sounds like your less-than-one-year-old phone is genuinely defective. And should be replaced. Hopefully warranty service would apply.
    07-20-2014 06:55 PM
  5. V J's Avatar
    Screenshots of your battery usage would really help us try and troubleshoot your issue.
    07-20-2014 09:20 PM
  6. Greg Wilkins's Avatar
    Was browsing yesterday about why I had power on lag, like 5 seconds, anyways, someone suggested pulling the SD card and try, well I ripped that baby out and the lag is gone and today I've gone 13+ hours and I have 72 percent battery! Wtf ! Not sure why this worked but I'm extremely happy! Give it a try
    07-22-2014 09:33 PM
  7. Greg Wilkins's Avatar
    Here you go
    Attached Thumbnails Note 3 battery drains really quickly-2014-07-22-19-34-33.jpg ย
    07-22-2014 09:35 PM
  8. Relgoshan's Avatar
    Bad piece of junk SD card basically. Either get like a Genuine Samsung or a Sandisk PRO if you want fast and reliable. Or what was in there?
    Here you go
    So I assume that was with less than an hour of screen time.
    07-23-2014 10:40 AM
  9. Greg Wilkins's Avatar
    It was a Samsung 8gb card, not a lot of screen time which is the norm for me, I drive a lot as I am a plumber, so usually I drain quickly from what I thought was network switching, so I've factory reset before trying to fix that, this time I removed the card and bam, it worked! Today I've had more screen time and I'm at 73 percent at around 12 hours! Maybe you can try and see if it works for you that way I'll know it isn't me! Lol
    shortwave8669 likes this.
    07-23-2014 07:46 PM
  10. shortwave8669's Avatar
    Sounds like an indexing issue related to files on SD card.
    Some users (who move many files on/off the phone) find using Samsung Kies rather than just drag/droping them helps...if that is the cause of your problem.
    07-25-2014 01:36 PM
  11. Greg Wilkins's Avatar
    I have no files on my SD, everything is on phone and its always been that way, that's why I was dumbfounded, I'm just happy as a clam now
    07-27-2014 05:59 AM
  12. Jalopiejoe's Avatar
    Are clams really that happy? ๐Ÿ˜†๐Ÿ‘Œ
    (I'm sorry, I couldn't resist! )
    Sent from my Samsung Galaxy Note 3
    "Size Does Matter!"
    anon8380037 and JimSmith94 like this.
    07-27-2014 09:09 AM
  13. anon8380037's Avatar
    "Size Does Matter!"
    Possibly. At a pinch!
    I thought I did all the bad jokes here!
    Sent from my SM-N9005 using Tapatalk Pro
    Jalopiejoe likes this.
    07-27-2014 09:40 AM
  14. Greg Wilkins's Avatar
    "Size Does Matter!"
    Only the bearded ones are from what I've seen
    07-27-2014 08:46 PM
  15. Parda Cyan's Avatar
    i had the same problem, when I Bought a 32gb kingston card, class 10, it drained the battery. removing "resolved" the battery issue BUT..
    does anybody have a solution for the problem, or is my card useless now..??
    should I take it up with warranty.. the phone's or the card's?
    04-08-2015 07:11 PM
  1. extended batteries
    By jneusch in forum LG G3
    Last Post: 08-12-2014, 06:15 PM
  2. Music on Note 3
    By petersull in forum Samsung Galaxy Note 3
    Last Post: 07-21-2014, 10:10 AM
  3. HELP! Samsung Galaxy Note SGH-i717 Problems
    Last Post: 07-18-2014, 05:01 PM
  4. SNote does not sync across all devices on Note Pro 12.2
    Last Post: 07-18-2014, 04:14 PM
  5. Samsung note 3 Pop ups
    Last Post: 07-18-2014, 03:39 PM
