Results 1 to 4 of 4
Like Tree1Likes
  • 1 Post By mdavisgtm
    Default My Custom made Note 3 wallet case
    So I got my Note 3 about 5 months ago and found that it was kinda awkward to carry it around and a wallet. I really don't like to carry my wallet in my back pocket its just not comfortable. So I figured that if I found a phone case that could carry a couple cards in it then I wouldn't even need to carry a wallet. All that I could find was those stupid cases that has a flap that covers half the screen, I don't want to be flipping open that flap every time I wanna look at my phone!! So anyway i decided to build a case that could do what I wanted. After lots of searching I finally found something that I figured would work:
    http://www.amazon.com/Reddot-winning-Protector-protection-gradually/dp/B007XU88ZE/ref=sr_1_177?ie=UTF8&qid=1405737746&sr=8-177&keywords=Aluminum+wallet
    Its got a little mechanism that pushes all the cards out for easy access. Then I got a plastic case for a Note 3, it was actually pretty hard to find just a plane hard plastic case, almost all of the cases out there have rubber or some other sort of padding combined with the plastic.
    When i got all the stuff I needed then I started putting it together:
    First I cut a hole in the case the size of the aluminum card holder:
    And then I glued in the Card holder using epoxy and bondo, and then sanded everything down:
    Once I was happy with it I covered everything with a carbon fiber vinyl wrap:
    It dosent look perfect, it was hard to get the wrap to go smoothly over everything so I got some wrinkles but its really not that bad.
    And it makes all the cards really easy to get to when you need them:
    Overall it turned out really good. It can carry 5 cards and I have never had a problem with the cards slipping out. I have been using it for about 4 months now. What you gain in the thickness of the phone you more then make up for in functionality. The phone with the wallet case is a little under 17mm thick and a regular Note 3 with a case is a little over 10mm thick.
    So that was my little project let me know what you guys think
    wizzrah likes this.
  2. #2
    Golfdriver97's Avatar
    Posts
    Global Posts
    32,699 Global Posts
    Carrier
    Pure Nexus/Franco Kernel
    Default Re: My Custom made Note 3 wallet case
    That is really cool!
  3. #3
    That looks nice and it does exactly what you want! 😆👌
    Sent from my Samsung Galaxy Note 3
    "Size Does Matter!"
  4. #4
    Brilliant!
    I'm trying to add a sliding lens cover to my LG G3 book-style case so that when I go to pull it out of my pocket, I don't plant a fingerprint on the lens. Judging by how it's shaping up so far, I shall not be sending photos of the end result.
  1. How can I see my entire text conversation?
    By streek405 in forum Ask a Question
    Last Post: 07-21-2014, 06:38 AM
  2. My S4 has slowed to a crawl
    By aflacks in forum Samsung Galaxy S4
    Last Post: 07-20-2014, 10:23 AM
  3. Replies: 1
    Last Post: 07-19-2014, 06:10 AM
  4. My samsung S3 its restarting by itself
    Last Post: 07-19-2014, 12:14 AM
  5. My Device Is not listed in the How to root phone page Help!
    By Unregistered in forum Ask a Question
    Last Post: 07-18-2014, 10:41 PM
