1. Closingracer's Avatar
    I have noticed that android system and os has been taking good chunks of my battery life even after factory resets and clearing cache. Been averaging about 3 hours of screen time till 15% where I used to average around 6-7.
    07-24-2014 02:13 AM
  2. ranajit saha's Avatar
    What services do you keep on?
    Yesterday in <12 hours charge had gone to 28% from 100%. I used 3G all day with 2.5 hours of screen on and 10mins of gaming. GPS, master sync, air view & gesture were on. No other app like battery saver which consumes battery is installed. Also no such app which runs in background and consumes a lot of battery. I don't know whether it's normal. Samsung service centre said it's normal. But I think it's not so good.
    07-24-2014 02:34 AM
  3. warn joe's Avatar
    http://img.tapatalk.com/d/14/07/24/y4e7ubah.jpg
    Well, I would say its bad rather than I would say that a good one ! I don't think that this is any matter of issue which you want to digg on . I didn't understand what else you are trying to get on as you are already getting great performance out of you Android device. :O
    07-24-2014 02:42 AM
  4. Closingracer's Avatar
    Yeah but under the same conditions before I now am getting about 3-4 hours less of screen time
    07-24-2014 02:47 AM
  5. warn joe's Avatar
    Well, I don't think anything more can be done with it ! Try installing some battery saver apps and see if they can help you out in getting some more juice out of it !
    PS:Tell you what, here I would say the changes observed by installing such application will only show minor increase ! Can really suggest more over it.
    07-24-2014 03:06 AM
  6. thegame161's Avatar
    Android system takes up 20+ of mine and I still get 4-5 hours screen time on 1 day of usage most days. So I wouldn't say that's causing it
    Sent from my SM-N9005 using AC Forums mobile app
    07-24-2014 03:23 AM
  7. Closingracer's Avatar
    I used to average 10%....
    07-24-2014 03:30 AM
  1. where do my downloaded books from amazon go?
    By kandi707 in forum Samsung Galaxy Note 10.1
    Last Post: 09-09-2014, 11:22 PM
  2. Nexus 7 battery life went to crap 3 or 4 weeks ago
    By OUGrad05 in forum Google Nexus 7 (2012) Accessories
    Last Post: 08-09-2014, 09:39 AM
  3. Replies: 4
    Last Post: 07-27-2014, 04:54 PM
  4. Mission to Improve S5 Battery Life
    By slaskwroclaw18 in forum Samsung Galaxy S5
    Last Post: 07-24-2014, 09:35 PM
  5. galaxy s4 not charging with new battery
    Last Post: 07-24-2014, 02:33 AM
