1. taposbd's Avatar
    Do not see the 4k resolution(3840x2160) in my note3 camera video setting.
    I did 4k recording from my note3 few days back. But suddenly I realize the option is no more in my note3. I upgraded the OS to kitkat and regularly check for updates. Im not sure if these happened because of those upgradation.
    here is the screenshot that I currently see in my note3 camera video setting. Please help.
    Attached Thumbnails Note3 camera doesn't show 4k resolution-2014-08-01-17-20-42.jpg
    08-01-2014 12:29 PM
  2. Nakrohtap's Avatar
    This is based on no research whatsoever...just a thought...does your phone have ample storage space for 4k recordings? Maybe there is a minimum limit where the system turns off the 4k option?
    Sent from my SM-N900V using Tapatalk
    08-01-2014 01:05 PM
  3. taposbd's Avatar
    Thanks. 15GB from internal storage and 22 GB from SDcard is available.
    08-01-2014 02:05 PM
  4. jpr's Avatar
    Make sure you don't have it set to the front facing camera.
    08-01-2014 05:29 PM
  5. anon8380037's Avatar
    I was hoping that might be it for the OP, but the other two options would be greyed out.
    http://forums.androidcentral.com/sho....php?p=3804870
    Sent from my SM-N9005 using Tapatalk Pro
    08-01-2014 05:35 PM
  6. taposbd's Avatar
    thanks JPR.. but its not set for front camera. its set for main camera.
    08-03-2014 04:29 AM
  7. shanghaichica's Avatar
    Have you tried a reboot or re-set the device?
    Posted from my S5
    08-03-2014 03:32 PM
  8. taposbd's Avatar
    Posted from my S5
    I restarted the device couple of times.. but no change
    08-07-2014 07:40 AM
  9. sunrat39's Avatar
    Go into camera then settings and there should be a gear icon. Top the gear icon and scroll all the way down and hit reset. It will reset the camera settings and hopefully it will show the 4k recording symbol.
    anon8380037 likes this.
    08-07-2014 07:56 AM
  10. taposbd's Avatar
    thanks.. but no change
    08-09-2014 02:06 AM
  11. shanghaichica's Avatar
    Have you tried a factory reset?
    Posted from my S5
    08-09-2014 02:42 AM
  12. anon8380037's Avatar
    That's still weird if you had it before. How about moving any 4k video off device and card.
    08-09-2014 07:42 AM
  13. sunrat39's Avatar
    If factory reset doesn't fix it then I wonder if it is hardware issue? If you do a factory reset take out the SD card (if you have one) when trying to check for 4k again.
    08-09-2014 10:37 AM
  1. [Galaxy Tab S 8.4] Homescreen Screenshot! Show us what you got! :)
    By Omer San Gabriel in forum Samsung Galaxy Tab S 8.4
    Last Post: 08-10-2014, 07:01 PM
  2. Replies: 1
    Last Post: 08-02-2014, 12:29 AM
  3. NotifierPro doesn't change sounds
    By emen8 in forum Ask a Question
    Last Post: 08-01-2014, 11:06 AM
  4. Sent texts not showing HTC Desire
    Last Post: 08-01-2014, 04:50 AM
  5. DockClock V1.3 for Samsung Galaxy S5, S4 & Note3
    By nfkxxx in forum Samsung Galaxy S5
    Last Post: 08-01-2014, 04:45 AM
