Results 1 to 3 of 3
    Default Problem with S Note - Little Help Please
    While I was able to do this in the past, I seem to no longer be able to insert a voice recording in S Note. If I hit the red record button, it now tells me I am already using the voice recorder in another app. I have cleared the RAM, closed all running programs and even rebooted. Nothing works. I fear it is a setting somewhere but I can't seem to hit on it.
    Additional: I have discovered that the only way I can make it work is to choose Text input vs the pen input. Is this by design? Seems kind of dumb
  2. #2
    Default Re: Problem with S Note - Little Help Please
    Did you try per the other thread today and turn Google Search on/off/clear.
  3. #3
    jpr
    jpr is offline
    jpr's Avatar
    Posts
    Global Posts
    1,702 Global Posts
    If you have "ok google" detection on, turn that off and try.
  1. So gear live works with WiFi.
    By aokusman in forum Samsung Gear Live
    Last Post: 04-22-2015, 07:38 AM
  2. Replies: 4
    Last Post: 08-13-2014, 08:14 AM
  3. Replies: 3
    Last Post: 08-07-2014, 06:19 AM
  4. need help to remember the name of a game
    Last Post: 08-07-2014, 04:04 AM
  5. Installed paranoidandroid, problem with wifi, HELP!!
    Last Post: 08-06-2014, 06:47 AM
