1. Nathan Crookes's Avatar
    Hello my note 3 always has my location as San fransico but i live in Japan, even with GPS on but only when im inside, but when im outside its all good but only when GPS is on when off it says San Francisco again. Its becoming annoying for things like checking weather, tagging wrong locations on photos and FB friends think I'm on holiday in San Francisco etc.... Does anyone out there know how to fix or have any theorizes!?
    Thanks
    Nate dowg
    The Force is strong within this Note!
    08-08-2014 09:02 AM
  2. conanheath's Avatar
    Is your time zone set right? Make sure in location settings you have it set to high accuracy. This will use network, WiFi, and GPS to estimate position. Sounds like you have it set to low accuracy which only uses GPS. Is your phone a import or local model? May have something to do with it.
    08-08-2014 12:00 PM
  3. anon8380037's Avatar
    There have been problems like this for me and others.
    It came back after a couple of months, but now it's OK.
    All I can suggest is uninstall AccuWeather if you have it, it's been under suspicion, and install GPS Status and Toolbox.
    Sent from my SM-N9005 using Tapatalk Pro
    Nathan Crookes likes this.
    08-08-2014 12:44 PM
  4. Nathan Crookes's Avatar
    Thanks for the advice conan , but I've already checked all that its been like this from when I first got it.
    Thanks
    08-08-2014 08:40 PM
  1. Location wrong (note 3)
    By Nathan Crookes in forum Ask a Question
    Last Post: 08-08-2014, 09:09 AM
  2. i have a notification problem
    By Hassan Younes in forum Ask a Question
    Last Post: 08-08-2014, 07:47 AM
  3. problem in dowloading for app from playstore
    Last Post: 08-08-2014, 04:37 AM
  4. problem in dowloading for app from playstore
    Last Post: 08-08-2014, 03:20 AM
  5. Replies: 0
    Last Post: 08-08-2014, 02:16 AM
