Results 1 to 3 of 3
    marselisgn3's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default note 3 quick glance problem
    everytime i hover my hand above the sensor, quick glance activates and makes a notification sound. that never happened before and dont want to happen now. i tried turn on off restart turn on off air gesture everything. does anyone else have this
  2. #2
    anon8380037's Avatar
    Posts
    Global Posts
    5,210 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: note 3 quick glance problem
    Touch Sounds in Sounds brings a water drop sound to everything except Quick Glance on mine. You could turn System sounds right down in Sound - Volume but it will turn off all system sounds.
    I can't find why it does that on yours.
    (Default Notification Sound - Dew Drop is a different sound!)
    Sent from my SM-N9005 using Tapatalk Pro
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    found what went wrong. apperently i turned on notification reminder something like that. as soon as i turned that off the problem was solved
    anon8380037 likes this.
  1. G3 Chromecast Connection Problem
    By mlett in forum LG G3
    Last Post: 02-07-2015, 03:53 PM
  2. Replies: 4
    Last Post: 08-25-2014, 05:23 AM
  3. USB connect problem -- not recognized
    By linter in forum Google Nexus 7 Tablet (2013)
    Last Post: 08-25-2014, 02:14 AM
  4. Samsung Note 3 Vehicle Bluetooth
    Last Post: 08-20-2014, 09:42 AM
