1. alpinecivic's Avatar
    I switched to TMobile in Feb from AT&T. I had unlimited data on AT&T and the most data I ever used was 13GB, granted I was throttled after about 8GB but still never went over that. (using an iphone)
    Since Feb, using my Note 3, I'm averaging 25GB per month, last month I hit 45GB, this month I'm close to 30GB.
    I downloaded a data manager app to try and pinpoint why I'm using so much data and for the last 2 months the biggest usage has been Android OS.
    Why is my OS using so much data? I'm not too worried since I'm on unlimited data with TMobile, but I have no idea why my OS is using so much data.
    Any ideas? Anyone else have the same problem?
    Attached Thumbnails Android OS using 11GB+ of data?-screenshot_2014-08-27-07-19-08.jpg
    08-27-2014 09:33 AM
  2. Golfdriver97's Avatar
    The only thing I can think of is Samsung is grouping Play Store, and anything else that Android does in one group. I am probably wrong though.
    08-27-2014 09:43 AM
  3. waz ahmer's Avatar
    My Android OS is 5.34gb check your manager folder
    Ulimate Note 3
    08-29-2014 08:33 AM
  4. goin_nil's Avatar
    Most likely the apps you use use Android media services to download/play media content. So this data is being classified as android OS services. I'd recommend finding a different tracking app to get better stats.
    Do you EVER use WiFi for anything? That's a TON of 4G data. 😲
    08-29-2014 05:16 PM
  1. Replies: 6
    Last Post: 08-30-2014, 11:05 AM
  2. Replies: 1
    Last Post: 08-27-2014, 06:28 PM
  3. Replies: 2
    Last Post: 08-27-2014, 11:03 AM
  4. not recieving e-mails on my android
    Last Post: 08-27-2014, 09:57 AM
  5. Android is downloading
    Last Post: 08-27-2014, 09:23 AM
