S Planner Issue - reminders won't go away
I use the S Planner a lot to schedule appointments etc.
I also set a reminder with a notification. So if I set a reminder for 15 minutes before a meeting, then 15 minutes before the scheduled time for the meeting, the reminder will pop up on the phone. You can then either slide it to "snooze" or to presumably go away, a red "X". I slide the X over to remove the reminder but minutes later it pops back up again. It keeps doing this over and over until eventually it goes away.
Does anyone know how to remove the reminder on the first try?
