Galaxy Note 3 SM-N9005 LTE problems, can I get some help?
A
AC Question
Hi, I have one SM-N9005, I recived the update to lollipop 5.0... I made the update... my note 3 are showing the option "LTE/WCDMA/GSM (auto connect)", I think don't need root my phone because I already have this option without root... BUT if I put a 4G chip on my note 3, It's never work, only get 3G speed... I use the same chip in other phone and the 4G works fine...
Somebody have the same problem?... have the option "LTE/WCDMA/GSM (auto connect)" but your phone never works with 4G?
guitarman
Re: Galaxy Note 3 SM-N9005 LTE problems
Hi B. Diddy, I open this post... My carrier are CLARO (at Ecuador), in the webpage of the carrier say support "AWS4 1700/2100Mhz"
In the link that you sendme have "LTE 2100 MHz".
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,592
4,732
113
No, that's the problem. Band 4 AWS is a combination of 1700/2100, so you need to see that combination listed in the phone's specs.
Here's another specs page that's a little clearer: Samsung Galaxy Note 3 - Full phone specifications. If you look at the specific bands supported by the N9005 variant, Band 4 isn't listed. 2100 Mhz alone is Band 1, which it does support, but that's not the same as 1700/2100 MHz. The other Note 3 variant listed, N900W8, does support Band 4, but unfortunately that isn't the model you have.
You can't add band support to a phone, so unfortunately, you're stuck with 3G speeds. From what I can tell on this website, the other available LTE band in Ecuador is Band 2 from Movistar, but your phone also doesn't support Band 2 (while the N900W8 does).
Sorry!
guitarman
Thanks for your help, I appreciate it.
Currently I hate the seller of Samsung at BestBuy store, he said the phone would work in my country :(
Thanks again for helpme. Have a nice day.
