Note 4 Phone Arena Review
thatdarnpunk
121
Re: Phone Arena Review
Wish it beat the iPhone in more benchmarks. Or, alternatively, if these benchmarks don't provide a good comparison, I wish reviewers would stop using them.
msavic6
714
I'm waiting anxiously for their battery life tests!
I also can't wait for the GSM ARENA, Annandtech and Ars technica reviews.
Sent from my SM-G900W8 using Tapatalk
asharrop
Active member
Nov 13, 2012
42
Seems like every review, including this one, can't figure out how to set up the finger print reader. Is it really that hard to figure out to scan your finger from 10 different angles instead of the same angle 10 times? Seems like common sense to me, and think I saw that the software on the note 4 even suggests this during setup if you read what it tells you...
sulla1965
2,635
114
63
Phone arena isn't that good of review site. I don't take much stock in any of their reviews. Especially Ray and John V. Both are clearly pro apple. Apple can never do any wrong in their eyes. Lame
jamesrick80
885
Don´t trust the higher FPS of the iphone 6+.
The benchmarks were not ready when phonearena did the test and they are rendering at 640 x 1136 during the on screen test (the resolution of the iphone 5s) instead of the HD resolution of the iphone 6+ (nearly 3 times higher).
Therefore the big difference in FPS.
I told phonearena several times to correct those values, but it seems there is no one listening...
anon(469638)
579
6
Exactly. While i still think the iPhone is easier to use, its not like the Notes is bad or inaccurate. My sister never has a problem using it on her S5.
Fr0gburp3r
796
What about offscreen?
smokedog87
