Page 1 of 2 12 LastLast
Results 1 to 25 of 31
Like Tree15Likes
    Default Look like the Note 4 will have pretty good battery life after all!
    Check out this battery test from Phone Arena, the Note 4 did exceptionally well!
    Surprise, surprise! The Note 4 defies expectations by acing our battery life test, becomes the longest-lasting QHD phone
    Thanked by 5:
    TheDonJ77, deeb215 and Tarek53180 like this.
  2. #2
    fwinst's Avatar
    Posts
    Global Posts
    761 Global Posts
    Default Re: Look like the Note 4 will have pretty good battery life after all!
    Why does every headline about the Note, on Phone Arena, include a snarky comment??
  3. #3
    This means with care, note 4 can have 9-11 hrs* screen on time at a full charge on stock battery. Truly remarkable.
    *This is calculated using the test of phone arena linked above, and my experience with Note 3's ~8 hrs screen on time on a full charge (with special care of course).
    3200->Centro-->Pre-->Pre2-->HOX/N4-->GN3/ZTE OPEN C
    Palm T|X-->Transformer-->Galaxy Tab 7.7-->iconia w510/GTS 8.4
  4. #4
    Linebarrel86's Avatar
    Posts
    Global Posts
    279 Global Posts
    ROM
    Stock
    Excellent.
    On one hand, I hate that I have to buy a phablet to get good battery life. On the other hand, great battery life puts me at ease knowing I want be hunting for a charger by 3 or 4pm.
  5. #5
    Quote Originally Posted by clevin View Post
    Doubt it's that good
    I get 4-5 hours on average.
    Owner of- Galaxy Note 3- Galaxy Note Pro 12.2- Galaxy note 8.0- Galaxy Gear 2
  6. #6
    That's great to hear. A couple quotes from the article...
    " This means that the average Joe should be able to squeeze nearly 9 hours of screen on-time with the Note 4 going through a typical daily routine of calls, texts, browsing, and games. "
    "... supports truly quick charging -- the massive cell of the Note 4 needed just 95 minutes to charge. That's an absolute record for a juicer this big... "
    But, battery use is such a personal experience. There are a lot of factors that influence it that you really can't rely on tests like these and expect the same results.
    Influencing factors are:
    - screen brightness
    - # of apps, media, files installed
    - types of apps used
    - overly aggressive app syncing (ie poorly written apps)
    - if you use WiFi mainly or 4G mostly
    - your proximity/distance to WiFi router (ie poor signal strength drains battery faster)
    - your 4G signal strength. I work in an office building and depending on which cubical I sit in (literally only 20 feet away) can make a big difference in battery consumption
    - probably lots more factors
  7. #7
    I hope so but I am not going to put much faith in PhoneArena ... Why you ask? Simply because they say "we run a script that mimics real world usage" -- Okay what do they consider as "real world usage"? It helps if they tell you everything so you can have a better of idea on what they think is "real" usage versus your own.
    Sent from my T-Mobile Note 4 using AC Forums.
  8. Thread Author  Thread Author    #8
    I dont think the take away is that you will get 9 hours of screen time, its that the battery is good so that however you use the battery, you will get more relative time than less.
    lazerproof likes this.
  9. #9
    Quote Originally Posted by David Lees1 View Post
    And I agree but when it comes to battery tests .. at least for me .. I have to know what they did. I can achieve amazing life on my Note 3 .. if I disable this, that, and that .. or that .. .
    So for me I just have to know what they did exactly in order to see if it was a true normal user experience.
  10. #10
    Quote Originally Posted by Almeuit View Post
    I agree with you... however, I don't think they are actually going for how it will work in your specific case in your specific way of use. They are using a testing program that simulates some sort of normal routine, rather than just running a video on full bright until the battery dies. The only way these numbers are usable to you, or anyone else is to compare them to other devices that were tested the same way.
    That way they can say that the battery on the Note 4 runs for 9 hours of screen life in our test... you discover that the same test yielded 7 hours for the Note 3. You can look at those numbers and say "I have the Note 3 and I get about 5 hours out of it, so I might be looking at about a 12-15% improvement over what I currently have."
    There is no way I can replicate my battery usage day to day, much less expect to replicate exactly what others have tested it for. I know I can squeeze more out of a battery, but what I really want to know when making a battery life decision, is it better than something else.. that I already know. I have a note 2, and have the 9000 mah battery. I am kinda getting sick of the bulk, but I really, really, love the fact that I can ignore the battery. My stock note 2 battery was not so wonderful. However, using these comparisons, I can see that there is a chance that I will be pleased with the stock note 4 battery.
  11. #11
    Quote Originally Posted by boufa View Post
    I never said anything about running a video at full brightness until it dies. They say their script mimics real usage .. What is "real" usage to them? Tons of webpages? A few YouTube? Music streaming? What?
    Until I know that I simply won't trust them. You can have your opinion on the matter but for me .. I only trust battery tests that tell me everything they're doing .. that way I can make my best judgement.
  12. Thread Author  Thread Author    #12
    I agree with you... however, I don't think they are actually going for how it will work in your specific case in your specific way of use. They are using a testing program that simulates some sort of normal routine, rather than just running a video on full bright until the battery dies. The only way these numbers are usable to you, or anyone else is to compare them to other devices that were tested the same way. ...
    This guy gets it.
    LegalAmerican likes this.
  13. #13
    Knowing this won't help you guage your own future battery life. The only validity in the test is that the same exact script (hopefully) was used in previous phone tests.
    Battery life is relative for every one and depends on tons of factors (even down to which versions of which apps you have installed vs someone else).
    I know what you want but your not going to get it. And if you did, it won't matter anyway.
    Get an extended battery (or extra battery) and free yourself from worry.
  14. #14
    Battery life is truly impressive on the Note 4.
    Look like the Note 4 will have pretty good battery life after all!-uploadfromtaptalk1412965330110.jpg
    Sent from my SM-G900W8 using Tapatalk
  15. #15
    Quote Originally Posted by goin_nil View Post
    Oh trust me I know my usage can't be compared on a battery test.. I can drop a battery in no time. I also understand how it definitely varies person to person and yes I do buy spares.
    But for me to know the stamina of the battery for the average user.. I have to know how they tested it. Just like when anything else in life is tested people won't trust "it just works I tested it".. Most will ask" how did you test it?".
    Again guys I said it's just for me.. No need to worry about trying to change my mind ... Also I'm not trying to say the battery is bad.. I just only like specific tests (I guess you could say that) .
  16. #16
    I already expected the note 4 to have great battery life. The note 3 had good battery life and easily got me through a full day. I can't wait for mine to arrive. I ordered one today and just got my confirmation email a few minutes ago. Now to wait impatiently. Lol
  17. #17
    From one geek to another, I can certainly understand that. Helps to validate the results.
    Thanked by:
    Almeuit likes this.
  18. #18
    If I get anything close to 6-8hrs of real usage on screen time, I'll be extremely happy. Only getting about 4.5hrs with my current S4, so doubling that will make a world of difference.
    Sent from my GT-I9505G using Tapatalk
  19. #19
    IrishFXDB's Avatar
    Posts
    Global Posts
    58 Global Posts
    Here's how I look at it... I get an average of 5 hours screen time on my S5 - sometimes a bit more, sometimes a bit less. The Note 4 did better in their test than the S5, so even if I don't know the exact method, I can still infer that the Note 4 will give me more screen time and that's all I need to know.
  20. #20
    +1, androidauthority only had about 4hr 25m screen on time, so the 9+hr seems unreal, they probably turned off GPS and cellular, which sucks up the most juice.
  21. #21
    Quote Originally Posted by SirMakoto View Post
    There's a difference between 9 straight hours of use vs. 4 hours of use with periods of idle time between uses. The Note 4 exhibits drain in standby so it's only natural to expect lower screen on time when large periods of idle are experienced.
  22. #22
    I agree. Likely on Wifi for the entire test. 4G/3G/etc take the most juice. And, the # of apps you have installed that are actively syncing data only makes it worse.
  23. #23
    IrishFXDB's Avatar
    Posts
    Global Posts
    58 Global Posts
    1. Find your current phone in one of their tests.
    2. Compare your real world results with their findings.
    3. Take the difference into account when looking at the results for the Note 4.
    I don't understand why so many people are trying so hard to discredit a favorable battery test. You don't have to know the exact specifics of the test, just use it as the baseline it's meant to be used as and move on.
    Like I said in my previous post, I average 5 hours of screen time on my S5 with my usage during a full day of 14-16 hours off charge. That's less than their results so I subtract the difference from the Note 4 results and that tells me I should expect an average of 6 hours of screen time on the Note 4.
    This isn't rocket science...
    Thanked by:
  24. #24
  25. #25
    And Note 4 battery life beat iPhone 6 plus badly
    http://www.phonearena.com/news/Our-i...tition_id60920
  1. Returning from opened links goes back to top of the page.. can I stop this?
    By Jodie Mansell in forum General Help and How To
    Last Post: 10-12-2014, 04:24 AM
  2. Replies: 1
    Last Post: 10-10-2014, 04:00 PM
  3. Why isn't my Samsung Note 3 opening to the homepage?
    Last Post: 10-10-2014, 11:00 AM
  4. Replies: 0
    Last Post: 10-10-2014, 07:02 AM
  5. Should I upgrade from the S4 to S5? Is it worth it?
    Last Post: 10-10-2014, 06:18 AM
