Note 4 Fingerprint scanner or not?
thegame161
1,298
How many are keeping theirs on? I have mine on right now as it's new but not sure if I will keep it for good or not.
Re: Fingerprint scanner or not?
I don't keep mine on because it doesn't not work he of the time
I plan on keeping it works great and what a convenience.
I don't use any sort of password entry for my phone. Annoys me. :P.
It is just as easy as swiping the screen. No accidental turn on from the screen swipe. I scanned two thumbs and right index finger and can use any of them at any angle, just swipe down. I have it set so it doesn't actually require a finger until it is idle for 10 minutes, screen swipe wakes it during the 10 minutes. I see absolutely no reason not to unless you are simply to lazy to swipe your fingers 10 times to set it up. Swipe at every imaginable angle you might use during the training and it works fricking great.
I don't simply due to annoyance... For you it works but I use my phone a ton during the day. Times it's on the desk and I just swype and unlock it and do whatever.. No worry about doing it properly on the button. One fail is enough to annoy me.. Especially since my phone is always on me so the security is a moot point.
As I said.. That's for me. It's cool if you feel different or have different needs :). Just isn't my cup of tea.. Locks for my phone never have been.
Hello, I'm having trouble with my fingerprint scanner. After I register my fingerprint it only works once I turn the phone off and back on. After the initial fingerprint scan if I lock it and go back to the home screen the phone no longer asks for the fingerprint but asks me to swipe to unlock. Does anyone know how to fix this problem? Or do I have a defective device :(
It set up easy enough but man I couldn't access my phone! So I turned it off :(
Try following the below screenshots. Ensure you have your lock screen set to fingerprint.
"Swipe the entire pad"
After seeing that for the millionth time I gave up.
Thanks for your reply. I originally followed all of the steps but no luck. Another used just created a thread with the same problem as mines. Hopefully we can get this resolved... thanks again for the screen shots.
Im going to try it for a few days. I registered 2 fingers.
Rocking the Note 4
No bc I'm using a gear fit, so it automatically unlocks the device when held together. Pretty cool
No worries. I replied to that thread with another suggestion :).
Yup the guys in the other thread sound like exactly the same problem. Seems "quirky" which would bother the heck out of me. Had a Lenova laptop that had the same kind of fingerprint scanner. The only thing that saved it is that it would take either password or scan. Got to the point where I would not even try the fingerprint scan. Was not worth the effort...just used password.
marik999
