On my Samsung Galaxy Note 4, where is the Led Indicator Menu?
bimoo
6
Samsung Galaxy Note 4 Led Indicator Menu !
Hello there
I got my Note 4 Yesterday and discovered that there is only Led Indicator Option to tick or Untick while in previous ones there was a menu that i could disable or enable the charging light and full battery light
if i untick it it will disable all the Led Lights e.g. no light will flash if i recive email or whatsapp for example ..i tried to install some apps but nothing will fix it
can any one tell me they have this problem or not ..i hate red light all the time while i am charging or green one if its fully charged it gets me confused now if its a notification for something i received or its just charging ..
please any one could help with that i appreciate it a lot
Re: Led Indicator Menu !
You could try Light Flow. It works well on my Note 3 but I can't confirm for a Note 4.
i am afraid thats one of the apps that i tried and not working with my problem..thanks
Re: Samsung Galaxy Note 4 Led Indicator Menu !
same problem. probably the most annoying thing about this phone
Just spoke with a Samsung rep:
"After verifying the resources, I am sorry to inform you that there is no option on the device to choose the LED indicator for specific notification."
EVERYTHING is customizable about this phone except this one simple thing that I use daily. I hope a future update will rectify this issue.
Agreed, it's annoying. I also wish the LED was brighter, like on my SGS3 (the last Samsung phone I had before the Note 4). But, maybe it just seems dimmer to me because I have a white phone so perhaps the LED just isn't as noticeable against the white.
There are several options you can choose to work with this.
No, you can't get rid of the Red/Green charging notification, but using 3rd party apps, you can change notifications on certain items. Textra and Chomp, for example, will change the color of the LED notifications. There are probably third party email apps out there with similar functionality.
These notifications will override the charger notification. i.e. if you have the Red LED on to indicate charging, and you receive a text, the LED notification for your text will override the red LED notification. This also works with Inbox and Facebook, although you don't get to customize the LED colors on those apps. You just get LED override on the charger notification.
Mine seems brighter because my SGS3 was white and my Note 4 is black. So you are right, it is more noticeable against black.:)
Lelix2603
