When I connect to Wi-Fi, it usually works as expected, just with slow data speeds (and it turns out that it's a network issue, not the phone). But occasionally, the phone keeps the Wi-Fi signal, but the Internet connection is completely dropped, which makes any app requiring Internet access useless. When I ask others around me who have phones connected to the same network, I see that they have Internet connection. To resolve the problem, I have to turn Wi-Fi off and back on again.
I've also noticed recently that sometimes the phone doesn't connect to the Wi-Fi network even when it's in range. When I see why, the phone says "Failed to obtain IP address." Again, turning Wi-Fi off and back on again fixes the issue. But in both cases, the fix is temporary.
Right now, I have the "Always allow scanning" turned OFF, location services are set to high accuracy, and Wi-Fi Power-save mode is enabled. The idea that resetting the Wi-Fi restores lost connections tells me that it's a software issue (i.e. easily fixed) rather than a hardware issue, but I'd like to know what you think.
Are there any known issues with Wi-Fi functionality in Android 4.4.4, and have any of you experienced the same problems as described above?
