Anyone found apps that actually use the finger print scanner such as a lock screen app? Hate the alpha numeric pass touch wiz requires
There is an app where you can set up where you can use the fingerprint scanner to log into most of your accounts or websites.
If you are interested I will look it up. I don't remember the name off the top of my head
John 3:16
Hey if you find it could you post it?
I'm confused because the finger print scanner is used on the lock screen if you have it set up that way. You don't need an app to do it. Just change your settings.
