Just guessing, because I never let my batteries get that discharged, but probably an indication that the battery dropped to below 15%. (Which should worry you, because, unless that happens only very rarely, you're killing the battery. Try to charge it when it reaches no lower than 40%.)What is this red line? Worries me :l
'Kill it' isn't really the correct term. But full cycles do 'wear out' the battery.
Charger early, charge often.
What's the difference?
When you run it fully to 0% and leave it there, there is a risk that the battery safety system will turn on, and the battery will be totally useless. That would be killing it. (lithium batteries require a number of safeties or they literally explode)
On the other hand, if you constantly do full charge and discharge cycles, the battery capacity will eventually become smaller and smaller. So instead of getting 20 hours from the battery, you only get 10 hours, because you are wearing it out.
You're fine recharging at 10-30%. Just keep doing your thing.So can we get a definitive consensus from the forum about this? Specifically in the case of the Note 4-Does waiting until the battery is low to charge wear down the battery life faster, or does charging early and often do it? What is best?
Just for the sake of testing my battery, I've been wearing my battery down to 10-30% before I charge it again to 100%
does anyone know offhand if the fast-charging feature raises the battery temperature? Although even if it does, the convenience of leaving that on outweighs the loss of battery capacity
It has to raise the temperature, ohms/watts law and all that. As the battery ages and the internal resistance goes up, it will only get worse.
But if you need it, use it, that is why you have it.
The Samsung spare battery with charging tray is only about $25 if you find a discount code. Very handy and not too expensive at all.
