did anyone come from the note 3 to note 4 if so What's the difference between the two besides the ca
iGalione
224
I came from the Note 1, to the 2, to the 3, to the 4... someone keeps knocking on my door... ok, let me stop
And each year it's a subtle yet needed upgrade:
for the 4, it included, a crisper and sharper QWHD screen, better than 1080p and just bright as can be
snappier performance than that of the note 3, by leaps, and you've noticed the instance with the better camera.
it's more of a premium build, the s-pen is more responsive and better at recognizing hand writing... I mean it's a great update, and to make matters worse, I just recently got the note edge as well... the 4 is definitely better, but the edge has some getting used to.
dpham00
Moderator Team VP
Moderator
Apr 23, 2011
30,108
200
63
My thoughts on the Verizon Note 4 advantages over Verizon Note 3:
-Significantly better battery life
-Significantly better radio, especially in lower signal areas.
-Runs substantially cooler
-Charges significantly faster with adaptive charging.
-Significantly easier to read outdoors
-Camera is a MAJOR improvement in low light/motion shots. Note 4 has OIS.
-Added fingerprint scanner (can be a bit finicky to use)
-Added Heartrate monitor
-Usage of Google "always listening" even when screen is off. Note 3 only had S-Voice always listening
Minor points:
-Added aluminum frame
-QHD
Cons:
-Marginally heavier (I didn't really notice it)
-No USB 3.0 (slower transfer speeds)
-A hair taller (I didn't really notice it)
-Speaker on the back
Sent from my Verizon Samsung Galaxy Note 4
asha_kanta_sharma
