I strongly disagree that RAW is useless on a cellphone. Or that post-processing would produce same results as .jpg.
Less useful than dSLR? Yes, even certainly... you are likely starting with more information/better pixels. Yet you could say RAW is useless on my 9 year old Canon Rebel XT... compared to newer cameras.
My argument stems from this: We can all agree the cameras capture RAW images already, right? But who is making the decision on how this image is processed? Who chooses the WB, saturation, tone, and compression? Currently, the phone's camera. It takes the raw image data does its "magic" or lack thereof, and gives you a rendered image... throwing away the bits it says you didn't need.
Oh, all your images have a strong bluish cast due to poor WB choice?... it went heavy handed in noise reduction? You can edit to some extent... but with the actual data having been thrown away there is only so much you can do. With RAW, that data is preserved for me to do as I wish. Maybe I want the same image processed radically different ways... having RAW lets me do that with the best quality for each rendering of the image.
Just because the starting point for my phone was so much lower than my dSLR doesn't mean I want whatever information WAS captured thrown away too. It's like saying a photo-copy isn't pristine anyway so why bother copying from the source document... why not just use a copy of a copy of a copy? <Answer: Because using the original source results in better output.>
I think saying its useless because it won't replace dSLR, or that "normals" won't know how to use it is a specious argument. I think we all know dSLR will typically take better pictures produce better images. But as stated previously its the camera you have with you... and I want the opportunity to extract the best that I can from what I've got.
As for the "normals"? I don't think its on by default (just as it isn't on most dSLRs.) So if they don't want burdened by extra storage space or hassle of processing RAW, they'll never see it.
Back to original question, though. Has anyone heard if Samsung, HTC, Motorola, etc will allow RAW capture (even with 3rd party camera apps?) For example, on Samsung HDR mode doesn't work in the Google Camera app.
