I have a new note 4 and im having bluetooth compatibility issues with my jaybird blubuds x!!!
I just upgraded from a samsung s4 to a note 4. I also purchased a pair a jaybird bluebuds x headed phones about a year and half ago and they worked flawlessly with my s4. Now with my note 4 the signal skips and cuts out so i performed a test and this is what i did...
So i did a through side by side comparison of my jaybird bluetooth headphones with my old samsung s4 and with my new note 4... the results are as follows. ... i identified that the range with the note 4 is markedly decreased. ( in other words i can't go as far a distance from the phone when i set it down without it cutting out)..and also ( and this is the wierd and most annoying one) i can interrupt the signal very easily and at very short range if i put my body between the note 4 and the receiver of the bluetooth headphones.. ( in other words unless the phone and the headphone receiver have line of sight contact, the signal will cut out very easily and consistently...
does anybody have any answers? I know that the bt version for the headphones is 2.1 and the note 4 bt version is 4.1... I have tried everything... yes i do have the new lollipop 5.0 os
