Help, I've created a default setting, how do I undo it (Photos)?
BitingPanda
Help, I've created a default setting, and I don't know how to undo it (Photos)
I wasn't paying attention, and I've somehow set my photo attachments to select from my Google photos cloud only. Often this means, the photo I want to share is not in the album to pull from, as I prefer that my photo backup only happens when charging/and attached to wi-fi.
How do I clear this setting so that all photo attachments are selected from my device Gallery?
Thanks!!
LeoRex
Retired Moderator
Nov 21, 2012
6,223
Re: Help, I've created a default setting, and I don't know how to undo it (Photos)
Go to Settings-Apps... The 'Photos' app might not be listed, as it really is just a sub-function of Google+... so click on Google+ is there's no Photos app. Click "Clear Defaults" under 'Launch by Default'.
If all else fails, click on the three-dot menu under Settings-Apps and select "reset app preferences"... but that resets the chooser prefs for ALL apps... and its basically a last resort since you'll have to answer all those prompts for all the other apps.
wei34
