Re: forgot my pin on my old note 4,how can i get it turned on and reset the pin
Welcome to AC.
Enter the wrong number a few times and it may prompt you to use your Google account details instead. However, it may do a Factory Reset. If you don't know which it does, log into Android Device Manager on a PC and change your device security details via that.
