03-20-2017 07:59 AM
28 12
tools
  1. OHegge's Avatar
    For those with issues connecting to a Windows computer, I was having a similar issue with a Nexus 7 and found this solution. I suspect it will work for the Note 4 as well:
    Go into Devices and Printers on your windows PC >>> Right click your Note 4 >>> Properties >>> Hardware >>> Properties >>> Change settings >>> Driver >>> Uninstall. >>>>> Done >>>> Then unplug the Note 4 and replug
    Thanks very much! That just solved the problem on my Note 4 and Win 10. :-)
    01-22-2017 06:18 AM
  2. katkothaza's Avatar
    Guys please try *#0808# and select MTP + ADB from the list and reboot to save
    Worked for me. Note 4. Thanks
    01-28-2017 05:31 PM
  3. kayehs's Avatar
    I tried the Android developer options suggestion, but I see no USB Configuration under developer options.
    03-20-2017 07:59 AM
28 12
  1. Replies: 0
    Last Post: 07-22-2015, 05:12 PM
  2. Replies: 0
    Last Post: 07-22-2015, 05:09 PM
  3. How do I back up my Samsung Note 2?
    By AC Question in forum Samsung Galaxy Note 2
    Last Post: 07-22-2015, 04:58 PM
  4. Why isn't my keyboard not working after resetting my Note 2?
    Last Post: 07-22-2015, 04:38 PM
  5. Replies: 0
    Last Post: 07-22-2015, 04:37 PM
