N Note4Beast New member Apr 16, 2016 3 0 0 Apr 16, 2016 #1 i found toggle app on play store but i need my original quick notification panel :'''(
evohicks Well-known member May 25, 2015 1,662 287 83 Apr 16, 2016 #2 http://forums.androidcentral.com/sa...lank-all-quick-icons-missing-i-need-help.html
N Note4Beast New member Apr 16, 2016 3 0 0 Apr 16, 2016 #3 thank you ☺ i will hard reset Last edited: Apr 16, 2016
N Note4Beast New member Apr 16, 2016 3 0 0 Apr 16, 2016 #4 Hard reset solved my problem, thank you ☺O
wess580 Well-known member Nov 12, 2010 279 5 18 Apr 16, 2016 #5 I know its late but see my post here a hard reset is not needed. http://forums.androidcentral.com/showthread.php?t=668340 Last edited: Apr 17, 2016
A Ashlheigh New member Jun 7, 2016 2 0 0 Jun 7, 2016 #6 My notification panel was missing ...any suggestion what to do ..thanks
R Ravin Shah New member Jan 18, 2017 1 0 0 Feb 17, 2017 #7 Ashlheigh said: My notification panel was missing ...any suggestion what to do ..thanks Click to expand... You can download aptoide apk from Google. Then download system ui. It will restart your phone. Then you can see all Toggle even mobile data.
B. Diddy Senior Ambassador Moderator Mar 9, 2012 169,740 11,154 113 Feb 18, 2017 #8 I would be very cautious about downloading and installing apk files from anywhere. It increases your risk of getting malware. Not sure how you can actually install a SystemUI apk, either.
