Hi there. My Note 4 front glass is coming off by itself. I had a replacement of screen done by samsung itself but it looks as if the screen isnt glued well. My question is simple(i dnt want samsung to open my phone again)
1.Should i remove just the front panel and put some adhesives then try sticking it again
2.Should i start by removing all 16 screws at the back then detach the parts one by one and glue the screen
