A
AC Question
About 3/4" across the bottom of my note 4 doesn't react to s-pen at all, and also, the back button reacts to the pen touch, but the recent apps button does not. I can't see obvious defects on the surface of the screen, neither is the phone in any case, magnetic or not. I did the Wacom Test on the phone and when the diagonal was drawn, the bottom corner tiles did not change color, nor did any line register and the phone returned a big red "FAIL". The whole screen, however, works perfectly with capacitive finger touch. I've done quite a bit of research online, and have found that problems with parts of unresponsive screen actually were caused by magnetic interference with a case. But mine has no case, and the problematic area is quite uniform across the bottom. Does this indicate a problematic phone, or is there a quick fix? Thanks to anyone who can shed some light.
