Hi all,
I have a note 4 for T-mo with Android 6.0.1 installed. I installed marshmallow as soon as it was available and have had no issues with it until now.
The issue? I can't take screen shots anymore. Every time I try to, I get an error that says.... Unfortunately, System UI has stopped. I have to press Ok 3 to 5 times before the error goes away for good. I was able to take screen hots for quite some time after the marshmallow update, so this is a fairly new problem. I haven't installed any new apps for quite some time, but that doesn't mean it's not an app issue, but i wouldn't know which one. Also, I went into recovery and wiped the cache, but that didn't fix the issue. Does anyone have a clue why this error has cropped up?
Thanks!
Clayton
Thanks!
Clayton
