I had been using a few cases with my note 5... originally got an otterbox symmetry but in time the thin parts of the frame around the rubber flaps both snapped which was annoying. I then switched to a second hand tech21 which was less bulky. At some point (don't know when it happened) I got a thin crack on my screen, all the way from left to right but you can't notice it at some reading angles, in others it jumps out. While the symmetry had originally come with a stick on screen protector I was unable to apply it without getting various specks of dust and hair under it to the point where I destroyed it in frustration.
Anyway after the crack I went and got a zagg screen protector which worked very well and did its job saving my phone when it got stuck being taken out of my pocket and suddenly flew free and landed on some tile, the point of impact shattered the glass of the screen protector but the note was fine. It did get some glass shards on the edge of the screen protector which kept getting worse, even messing with the proximity sensor so i had to remove it, and decided to get a case with a built in screen protector... though I was leary of the size of the otterbox defender.
Anyway I ended up getting a supcase unicorn beetle pro, black/blue, what they call blue is more cyan. It came with a holster which I never have luck with, but its there anyway. I used to always have a problem where my t-shirt would get between the phone and the holster as i tried to place it in there and then it would be lose or fly out or whatever (this on earlier phones/cases with holsters).
Thus far, my thoughts on the case:
1 - it fits very snugly. this is good, not gonna pop out like some other cases I've used after a spill...
2 - however, it is not the kind of case you casually remove your phone from if you want to show it off naked.... it takes a bit of work to remove it and then put it back on, and its the kind of work that makes me worry long term it might damage the case if you do that a lot.
3 - I am very fond of my fast wireless charger (a seneo). I was used to casually dropping my phone onto it for charging. This was never an issue with the Tech21 (I didn't have the charger when I had the symmetry). Well now I dropped it in... and nothing. I tried sideways and nothing. Then fiddling with it I got the charger light to turn green which normally indicates charging but the phone didn't show charging. After positioning it carefully i got the ding and it was charging. So basically the positioning is less forgiving with this case on, but it does work. After a while I was pretty good at getting it on there, but it still impacts how easy it is to drop the phone on there, and that is with a charger that holds the phone angle, with a flat surface it might be more finicky.
4 - about the only major negative, it impacts the sound quality other people get when I use the speaker phone. This is a bit of a bummer.
Aside form that one last issue I like it quite a lot. I'll probably just use my bt headset more, I guess. I'll check back after using it for awhile to see if my opinions change on it...
