Note 5 Quick Charge Car Charger
MedicD
286
Hi Guys,
I'm on the road a lot so I need a decent car charger with Quick Charging in case I'm in and out a lot. I got a one and and figured someone else out here might be looking for one. I got the Tronsmart TS-CC4P 4 port.
The short part of the post if you don't want to read: This one works great and doesn't take up a lot of space.
http://www.amazon.com/Tronsmart®-Qu...ag=hawk-future-20&ascsubtag=UUacUvbUpU4640162
It has 4 ports total, 3 of which are able to do the "normal" 2 amp 5v charging that Samsung devices used to come with, and then the other port is capable of also QualComm Quick charging, which is 1.67 amp 9v charging.
I've never used all 4 ports, but I have used 3 simultaneously and it didn't seem to slow down the charging on any device (Note 5, Note 10 2014, and Gear S all at the same time). I suppose I can now let my co-worker charge his iphone now too...eh nevermind :D
20150824_224448.jpg20150825_172550.jpgScreenshot_2015-08-26-22-08-49.jpg20150824_224719.jpg20150824_224726.jpg20150824_224734.jpg20150824_224755.jpg
Rukbat
Retired Moderator
Feb 12, 2012
44,529
26
Just a short note, if you don't want to read The Care and Feeding of Lithium Polymer Batteries. Letting the battery drop to 4% regularly will mean frequent battery replacements. Try to limit the drain to 40% - then charge it. (It's the way lithium batteries work - there's nothing we can do to make them deep charge capable and reasonably priced at the same time.)
And thank you for bringing the charger to everyone's attention. It seems like a nice charger for the price. Your link may be a bit munged, though, so this one works.
MedicD
286
Thanks fixed the link. I thought that issue with draining all the way wasn't an issue anymore, but thanks for the advice. I typically try to keep it higher than that, but just got a replacement today (switched out from 32GB to 64GB) and it came with around 55%. I am trying to find what's draining my battery so I'm slowly installing stuff and watching the drain. I'll be keeping it generally more charged. I'm kinda paranoid about having my phone die...especially once Samsung Pay comes out and all I carry is my phone and an ID.
anon(9652351)
210
I don't use aftermarket anything. I bought the Samsung adaptive quick charge car charger. Works as advertised. I cover my *** just in case Samsung says "we can't fix that, you used an aftermarket non approved charger"...
taylorhudson5670
