So I'm simply want ios like notifications on my lock screen.
Fluid and simple notifications.
I'm using something called screen on or something that turns the screen on when a txt or email is received.
I just downloaded an app from the play store called notify beta. Has great animations on when a notification is received. I also downloaded an app called headsoff to make sure there is no issues.
I cannot access the settings of notify beta. It's greyed out.
I added notify beta to the screen on app but my screen still doesn't light up.
Any ideas for simple fluid txt notifications or some way with a quick reply from the lock screen with fingerprint security enabled. Please help. Driving me crazy!!
Posted via my Samsung Note 5
