Choetech fast wireless charging pad review
dpham00
Moderator Team VP
Moderator
Apr 23, 2011
30,108
207
63
I saw the choetech fast wireless charging article on Android Central and wanted to give it a try
http://www.androidcentral.com/choetechs-fast-wireless-charger-effective-and-affordable
Physically it looks fine, it lights green when connected to a quick charge 2.0 charger, otherwise it will light blue. The charging pad is slightly wider than the note 5. It has a anti slip ring, so it shouldn't slide around even when going bare back.
It was pretty easy to use and charge, and the phone does have a notification for fast wireless charging.
With the screen off, it charged at an equivalent 5v,1.7a for a short while, then went back to 5v,1a equivalent charging, and tapers off at around 90%
With the screen on, it charges slow below 5v,1a, and as it gets warm, charging starts to trickle. I wouldn't recommend usage with the screen on while using the choetech fast wireless charger.
Nice review, dpham :).
This is a must have -- As I have heard some pads don't have that and the phone could slide off. That would scare me lol.
Most definitely. My old lg and Nokia plates (regular qi) don't have it and the phone can slide around.
r3dpuk3
