Help! Why are my incoming calls being blocked?
anon(7894520)
766
Please any clue is much appreciated.
As the screenshot shows some incoming calls apparently at random are being blocked. I get no notification in the lock screen or notification window that the call was made - it will just appear on the phone log.
I have no numbers on the phone block list nor do i use any third party blocking app.
What usually happens is the phone will ring once or twice before it decides to "block" that particular call. Some of the contacts are on my contacts list.
I have the international unlocked version.
Thanks for any assistance!
charles777
315
Do all the blocked numbers have something in common? Until you figure it out you can install a 3rd party dialler like truecaller and see if it makes a difference... you may have to try a hard reset unless somebody else has a better suggestion...
anon(7894520)
766
Nope, nothing in common. Some are on my address book, some are mobile numbers, others land lines...
I did install Drupe recently which is the only app that might affect it. Anyone here use Drupe?
