Note 5 Battery Dying Suddenly
Dec 26, 2013
1,027
With increasing frequency, my Note 5 battery will lose it's charge insanely fast and I don't know why. One time it happened when my battery was at 35%. The most recent time was when it was at 24%. I saw it was at 24%, put the phone down and went back to what I was doing. Minutes later, the phone was out of juice and I wasn't even using it. I attached a picture where you can see the drop off. Is anyone else having this issue? Normally I charge my phone between 30-40%. More recently I have tried letting the phone run out of charge twice thinking it was just the OS not calculating how much charge I had left properly. I don't know what is going on. I don't know what app could possibly suck away so much power so quickly.
Here is a pic of the drop off.
https://onedrive.live.com/redir?res...authkey=!AMEz79kQj7hivsY&v=3&ithint=photo,jpg
novice
148
I'm having the same problem. Will go from 30% to zero in 10 minutes on occasion.
Going to try a factory reset to remedy the problem.
sup3r1or
253
I have same issue or even worse one. I can get a max of 2 hours 40 mins of screen time. My battery would drop off like crazy. Phone shuts down at 16%. Once when I reached 20% I enabled Ultra power saving mode the black and white. Every minut I would loose 1% doing nothing. In 15 mins phone was dead.
Taking it for replacement battery on friday hopefully warrantly will cover my phone is almost a year old.
mlbyanks11
642
4
18
I've had the same issue it drains too fast without even using the phone. Idk what apps are causing it either. Strange I know. I used to get this phone through a whole day now I charge it at least 2 to 3 times a day.
Trees
1,544
12
38
GSam Battery Monitor has helped me in the past when trying to diagnose unexpected battery consumption.
Aug 25, 2016
7
Have you tried to calibrate the battery by letting it drain then charging to 100%? If so have you been doing that charge cycle 1x once a month or every 3 months? It is suppose to help maintain the battery. Have reduced the number of apps running in the background or switched to a power saving mode when the phone is idle? I do hope that helps I was not joking about my screen name. I am also having battery issues. Greenify has been recommended to me to analyze/maintain apps.
jeneral2
