Ok I need some advice on what I should do, maybe someone else has had the same issue, idk.
So here it is. Got my note 5, started it up, it was almost dead at 1%, the guy in the store charged it up to 10% and then since they were about to close, pretty much booted me out the store. No biggie. I went to go eat and I did all the updates, going from Android 5.0 to Marshmellow.
And here is where the fun begins. Yesterday my phone would not access Youtube. It kept saying, "No Connection" I thought maybe it was a network issue, so I restarted it and it worked fine. Well 2 hours later, I got home and I was on wifi, Again, started up Youtube and I got "No Connection", I cleared out the cache and everything and it worked fine.
I was a little worried since I just got this phone, so I called Tmobile and they said that I was under Buyer's Remorse and I could return it. I asked if the re stocking fee applied and they said no since it was a technical issue. So she told me she was going to reset my data and to restart the phone and that she would call me tomorrow. Ok, so I did that and then this other message comes up, everytime Irestart my phone. Saying something about, "Not able to process my request at this time, please use network instead of wifi", so I turned off wifi, restarted it and it come up...3 times. So at this point, called tech, they told me the same thing about buyer's remorse and I said ok.
Well I wiped the phone or did a hard reset and now the problem seems to be gone. I am a little worried though because I still have time and I don't know if the phone will continue to do this or not and I shouldn't have all these problems with a phone.
However, all I have for entertainment is my phone and while a S7 is ok, its a small screen and I don't have money for a laptop right now. So what do you guys think? Has anyone had this issue before? Should I just let it go since its not doing it anymore? Or take it back while I still have time and get another one?
Btw, it always says when I restart it, "Auto update of time and date" Is it supposed to say that? I have had a Note 5 before and I don't remember that.
