I have researched the issue of my Note 5just being able to slow charge via USB, and not be able to do anything else. I have tried all the proposed solutions I found, but can not fix the issue. The things that I have noticed to not work are:
What I have tried to do to fix:
Any insight on this issue would be appreciated.
Thanks
- Fast Charge: Cable and USB charging is detected, but cannot fast charge. I have tried the same charger and cable on other S7 edge, and it able to Fast charge. Fast charging is enabled in the battery menu
- Connect to PC: Whenever connected to any PC, the PC shows “USB Device Not Recognized." I have the latest version of Smart Switch and the latest drivers. I have tried multiple computers and windows 7, 8 and 10. I have also tried to connect to the PC when the phone is in Download and Recovery mode and get the same error.
- Connect to any OTG peripheral: Nothing is detected by the Note 5. Same cable working on other device.
- Connect to Gear VR: When connecting to Gear VR, it gives the chime, the black screen with the little x in the corner appears for a second and then it goes back to the home screen.
- Different cables/chargers/USB ports
- Checked if any of the 5 pins are broken in the cable
- I have lifted the tongue of the charging port in the phone via tooth pick
- Done a factory reset
Thanks
