Well, I found on Verizon's website it is just a security update. Hopefully it fixes the bad battery life that resulted from the last update in early Dec.
I know less than a day is not a good test, but to me, the update today helped considerably with the battery life. We will see over then next few days for sure.
Current Software Update Benefits
Software Version: MMB29K.N920VVRS3BPL4
The current software update gives you the most up to date Android™ security patch on your device.
