When I enter text into S Note via the keyboard, A blue box appears with blue dots in the corner. The text is entered inside this blue box and when return is entered the cursor moves to the next lne abd the blue box expands. My problem is somtimes when I go back into a S Note to edit it, not all the text that i had enterened is displayed. Sometimes I can scroll the text up and down to get to the end. However, somtimes a small blue trianle appears in the bottom right corner of the note and pressing this will display a new screen with the complete note shown and I can scroll the text if it too much to display on a single page.
My problem is I can not edit the text when this new screen is display and if I return to the normal screen to edit it often the lower half of the text is not displayed but the blue box is shown but with only half of the text that has been entered and the rest of the blue box is empty.
I am guessing that the blue box is used to define the text entry area and display and in many cases it works well, But if I accidently mobe the lines or the position of the blue box then the text when entered is ok for the first line but pressing the return key no longer makes the blue box expand but adds the small triangle. I can still enter more lines of text but when recalling the note to view all I can see is one line of text and then pressing the blue triangle display all the text on another window.
Is there anyway I can stop the blue triangle appearing and make all the text entered display on screen. Better still is there anyway to get rid of the blue text enry box. I have two Note 5 and they both have this problem. The latest software is installed and the phones are running on android 6.0.1
