I'm getting tempted to flash the file myself.
You're stronger than I could have been, especially after seeing the difference that Nougat made on my S7 Edge. I'd have given in weeks ago if Verizon hadn't pushed it to my Note 5.
I can't imagine that there are any carriers that haven't pushed it yet, and I've seen a bunch of firmware released for models all over the world. I'm not so sure about a US unlocked model though. Has that been pushed as well?
Miss my note 5. Curious are any of you going for the Note 8 when it's launched? Anyone go back to the note 5 after the note7 recall
because it was an edge display and will probably skip the N8
I'm on T-mobile and just got it yesterday...and am in these forums looking for solutions to the problems I had with it. :\
What do you seem to have trouble with? Did you get the update Over the Air (OTA)?
OTA...as in I woke up to a message that said I had an update ready, then yes. Things like the scrolling screen capture disappeared and I have a DND app that runs at night and it's not working as it should...software stuff, I'm sure.
Well, just tried to access Settings and I can't scroll up on the screen...it just bounces but I know there are more options there. But I did find a scrolling screen capture option... it was moved.Have you tried a cache clear in settings>storage?
Well, just tried to access Settings and I can't scroll up on the screen...it just bounces but I know there are more options there. But I did find a scrolling screen capture option... it was moved.//uploads.tapatalk-cdn.com/20170524/03848c1b3f0e66c83c60436f9a5f31e5.jpg
Nougat is not all that its made out to be,
More of a pain in the as s AS BUGS keep showing up
Yep... It still had not been launched for the China/Hong Kong device.Yep unfortunately the SM-N9200 for China and Hong Kong is still waiting for Nougat to be published
