"Remote Call" issue.
jordans0nly
446
Very curious as to what this is. I know this is not a 3rd party app problem, because I put the phone into safe mode, still there. Just happened out of the blue.
It's something Samsung related. I looked through Package Disabler Pro, didn't see anything out of the ordinary.
As I understand it, the remote functionality seems to work through components of both applications. I disconnected my tablet from my Message+ account (leaving Advanced Calling enabled) and the Remote Call went away. I expect that disabling AC would have accomplished the same thing.
I would ask Verizon if we will have the opportunity to disable that feature. I'd hate to have to disable AC in order to continue using Message+ without the additional notifications.
Well, I disabled Message+, still had the remote call icon. I do not have any other devices. So for me, the tablet discussion didn't help.
I believe there's a page from Verizon where you can see the devices linked to Messages+. Disabling the app wouldn't have gotten rid of the message if your account is linked to another device (maybe the web page counts as a device?). Advanced Messaging, however, if disabled, does disable all advanced services, but you might run into issues with people using AM when you reply to them (separate threads, some 3rd party apps not being able to access those messages, etc.).
This is indeed caused by Message+ and simply disabling the app won't make the notifications go away. Once Message+ has a connected device, it will integrate with your phone app, so a few more steps will be necessary.
First, you need to find the remote device(s). This device can be a tablet, PC, or any device that has had Message+ or Verizon Messages installed on it.
To do that open Message+>three lines at the top left>settings
At the bottom, tap on "Manage Devices" and remove whatever device is connected.
That will unlink the device, but the remote calling is still integrated into the phone app. To remove that you will need to go to your Application Manager and clear the App Data for every instance of the Phone app.
Once you have done all that, restart your phone. You should no longer get remote call notifications.
RangelS25
