Link: https://forums.androidcentral.com/e...hd-dry-full-body-galaxy-note7/&token=mjJJQ5hG
Install is pretty easy. You just have to make sure that it's on there good before you remove the final piece or else you end up with a lot of bubbles that are near impossible to remove. I learned the hard way and had to get another. It actually adds a ton of grip.
Installed:
Installed:
