Nope. I couldn't see notifications from across my bedroom when glancing on my S7 Edge. With the LED, one can.It doesn't really matter since the Note7 has the always on screen..
This. And always on display for messages only work with the crappy stock messaging app.
They have Note 7 there to play with?I went to Best Buy to check out the phone, and I saw the LED notification under the display settings.
Can we set different colors for different notifications?
When looking at that video where it's a purple led they are using iris scanner wouldn't that be the infrared sensor associated with that not a notification?I don't see why not. That's usually always been the case with a third party app. I use light flow.
