angiebugg
Black and it is a lighter black. almost charcoal grey. There is also blue and pink - at best buy anyways.
I turned "Limit notifications" to off in the Gear app on my Note 7. Since upgrading from my Note 4 my regular email notifications stopped appearing on my Gear S2. Now that I've changed that it seems to have fixed that issue.
Now if they'd just push out a fix to keep my watch from ringing when I get a call even though it's set to vibrate only. ><
I decided to reset my phone and that did the trick. All is well and I'm getting my notifications just fine now.
I had the same problem until I removed the sticker on the bottom... THANKSI have been bothered by this for the most part of today as well. I was about to give up i had actually taken the watch off and then i noticed there is a white sticker on the bottom of the watch. I peeled it off then tested again and it works perfect. Wow i feel like an *****. I guess that sticker blocked the sensor and was detecting that it was on my wrist. Not sure if this is whats wrong with you but its what was with me.
