Hello.
I have a brand new and possibly explosive Note 7. I have researched alternative phones and find that I want my note 7, just not one that will ignite.
I have found a way to cut back on the risk if using my current Note 7 until the less volatile version is sent out. Since it seems to be a fairly simple fix I thought I would share.
Go to Settings->
Go to Battery->
Go to Advanced Settings->
DISABLE fast cable and fast wi-fi charging.
I have been reading a bit and have seen a few reviews that state other phones also get quite hot- the Galaxy S7 and the Motorola Z force to name a couple. Both are prone to getting hot. Both also offer fast charging. Not sure if this helps anyone, but my phone doesn't feel as warm on the charger since slowing the charge rate down. Granted, my phone never feels hot just slightly warm when under heavy use. My phone is from Verizon and was manufactured in Korea. I plan on bringing it back to the store as soon as the new Note 7's are available but since my hubby took my old phone I am up a creak without a paddle till then. Again not sure this helps anyone, but it can't hurt.
Go to Settings->
Go to Battery->
