Does anyone else have an issue with their new device where the screen at max brightness is considerably dimmer than their old model ? I turned off auto brightness and cranked it up to max and it still looks about the same as my Nexus 6p, where it used to be much brighter. It also continues to auto dim everyone once in a while even though auto brightness is turned off.
I also get a message now when cranking up to max brightness that due to overheating you cannot raise the brightness any higher. Never had this message on a Samsung phone before. On a similar note, when changing the screen mode between ambled cinema and ambled photo, there is virtual no difference. Whereas as my tab s2 for example, there is a considerable difference between the two modes.
