1. Abhilash Nair's Avatar
    Hi ,
    Does anyone know the APN Settings to be used to get 3g network on ATT go phone ? This is now available in Amazon , but comes with default 2g APN (EDGE Data) settings.
    Samsung Galaxy note 8.0 LTE international version unlocked GT - N5120
    08-25-2013 01:22 PM
  2. Sweet Pikake's Avatar
    This is AT&T APN and I get HSPA+
    08-26-2013 02:44 PM
  3. Abhilash Nair's Avatar
    Hi , Thanks . I 've tried the settings and still get EDGE 2g data.
    The only difference i see is you are able to set the APN type to default, mms etc. I dont have an option but instead a drop down menu for Internet + MMS or internet or mms stand alone. I selected internet + mms and get only EDGE 2g data.
    I called AT&T and they mentioned the below frequencies . Would you know how to set it for 3g UMTS, as i think thats the issue as we are getting GSM 850 and 1900 MHZ only.
    4G-LTE Band 4 and 17
    4G HSPA+ HSPA+ with enhanced backhaul
    3G - UMTS 850/1900/2100MHz
    GSM/GPRS/EDGE 850/900/1800/1900MHz
    08-26-2013 11:16 PM
  4. Sweet Pikake's Avatar
    I have the GT-N5100,
    the specs
    Samsung Galaxy Note 8.0 N5100 - Full phone specifications
    if you have the GT-N5120 AT&T that comes with LTE, you might try this trick I made with my SGH-I337, may or may not work.
    Can I switch/select cell bands (LTE/3G/Etc) on the S4 /ATT/i337?
    or you can go to the last page of this thread and install the phone info app I have link to.
    08-27-2013 12:59 AM
  5. Abhilash Nair's Avatar
    The phone info app available in play store no longer works to change any thing, but only does a display. I see from that my network type is set to 2 - EDGE and not 3-UMTS. So i believe this is the problem. Need to find a way to change the network type on the GT N5120 model International version .
    08-27-2013 06:14 PM
  6. AZBrowncoat's Avatar
    How would this Phone/Tablet work with T-Mobile?
    According to T-Mobile technical support the frequencies available in my area are 1700, 1900 & 2100 mhz.
    Thanks!
    the specs
    09-30-2013 03:16 PM
  7. bowielai33's Avatar
    I had the same issue, the N-5120 international version can only receive "E" edge network type with T-mobile sim card in LAS VEGAS area. But with the same sim card, my other LG phone can get "4G" network. I had double checked the specification of two phones they both have the same GSM band (850/900/1800/1900). If the phones both are running thru the GSM band to connect to the network, they should have the same 4G network???? I tried to disable the mobile data, registered to the t-mobile network by choosing different network selection mode (LTE/GSM/WDCMA) and (GSM/WDCMA = this is the default mode on my LG phone), still got only "Edge" network type! Can anyone know how to fix this?
    04-11-2014 12:56 AM
  8. windboater's Avatar
    hey Sweet Pikake. why were your apn settings taken off the site. I could sure use them. Samsung updated my software and I ended up having the do a factory reset. Hasn't worked right ever since. John
    06-26-2014 10:02 AM
  1. Help with rooting Galaxy S4 Fido SGH-I337M 4.2.2
    By kasek in forum Samsung Galaxy S4 Rooting, ROMs & Hacks
    Last Post: 09-04-2013, 07:42 PM
  2. internal memory
    By thaphoenix2 in forum Verizon HTC One
    Last Post: 08-28-2013, 09:09 AM
  3. Samsung Galaxy S2 charges slowly
    By Huong Ninh in forum Samsung Galaxy S II Skyrocket
    Last Post: 08-26-2013, 11:42 PM
  4. Contacts icon and contacts missing on wife's phone.
    By heavyvino in forum Droid RAZR
    Last Post: 08-25-2013, 09:44 PM
  5. LG Optimus P880 4X HD Connect To Samsung TV HELP !!!!
    By Joshua Falls in forum LG Optimus 4X HD
    Last Post: 08-25-2013, 01:00 PM
