1. JordanCS88's Avatar
    I just bought the samsung galaxy note 8.0 and the USB adaptor cord. When I plug my hard drive in it recognizes it's connected but I can't find it in my files. What am I doing wrong?
    10-27-2013 05:59 PM
  2. DarthPaul's Avatar
    There is probably not enough power from the tablet to spin up the external hadrdrive. If possible, attach a powercord to the harddrive and see if that works.
    DarthPaul
    10-28-2013 02:41 PM
  3. lopezra20's Avatar
    DarthPaul
    I have the same problem, so I got the OTG cord and connected my hard drive to a cord containing another usb connection to power up my hard drive and still couldnt find it in My Files, or Storage from Settings. I dont have a computer so I want to transfer files from my Galaxy Note 8.0 to my hard drive. Havent found the right answer yet. Hopefully someone out there knows how
    02-23-2014 10:26 PM
  4. Darth Mo's Avatar
    Did you try a third party file manager such as Astro or ES File Explorer?
    02-24-2014 11:39 AM
  5. Eng Ahmad Nour's Avatar
    Simply, you have to be rooted
    then use "paragon ntfs"
    03-03-2014 11:20 PM
  1. S Voice no network connection error.
    By NCARalph in forum Samsung Galaxy Note 3
    Last Post: 03-09-2016, 10:03 PM
  2. ISSUE: 4G Icon & Signal Bars Go White. Help?
    By Jesus Delgadillo in forum Motorola Droid MAXX
    Last Post: 10-29-2013, 10:23 AM
  3. HTC One S took a nasty fall and I need help diagnosing issue
    By Christian Snider in forum T-Mobile HTC One
    Last Post: 10-27-2013, 08:30 PM
  4. Jabra bluetooth won't connect
    By stryper in forum Verizon HTC One
    Last Post: 10-27-2013, 05:14 PM
  5. HELP! TWRP Broke my Neux 7? STUCK ON X SCREEN!
    By too lame to come up with a good username in forum Google Nexus 7 Tablet (2012)
    Last Post: 10-27-2013, 02:12 PM
