Results 1 to 8 of 8
    streetslide's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Navigation without Wifi?
    What is the best way to navigate on a Wifi only Note 8 without WiFi? I know you can download a map from Google offline & when/if you find a wifi connection it will tell you where you are. That is the basically like having a paper map. I found some Apps that look like they use the GPS to turn by turn? Does anyone have real world experience using them, especially in the US vs. France? I thought I read somewhere you could connect to you cell phone via Bluetooth vs. tether and do it that way.
    What I am trying to do is navigate using the WiFi only Note 8 (big screen) vs. cell phone (little screen).
  2. #2
    Adamsberg's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Living in Europe there is roaming all around, therefore one needs offline navigation.
    I use the paid offline navigation app Navigon by Garmin and I've experience also in France ... but not in US
    You might also look for CoPilot and Sygic, a free app is NavFree ...
  3. #3
    dadathepanda's Avatar
    Posts
    Global Posts
    1,165 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Navigation without Wifi?
    But the note 8 has a GPS chip...
  4. #4
    Adamsberg's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by dadathepanda View Post
    Yep, necessary for offline navigation.
  5. #5
    rtronick's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    As dadathepanda said. There is no need to navigate using wi-fi. The Note 8 has a GPS chip. Just turn it on and you're ready to go. If you want turn by turn directions, look in the Play Store for navigation software.
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I know what I did now. I must have just brought up Google Maps and did not navigate to any address. I was thinking it should follow my route like a normal GPS (Garmin). This time, I made sure GPS was on & navigated to an address, all worked as expected. Then for fun I tried without an address again & that basically sucks because the screen turns off & you will drive off the screen without the screen re-adjusting.
    Bottom line is - just having a map up is a waste, GPS turn by turn navigation by destination works fine. So no biggie, I will just use a general destination and off to see the wizard.
  7. #7
    Adamsberg's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Only make sure that Maps calculates the turn-by-turn route on the downloaded (cached) area while you're on WiFi.
    Because Maps will indeed turn-by-turn navigate without WiFi, but it won't calculate or recalculate a route without WiFi.
    streetslide likes this.
  8. #8
    TheMetalman's Avatar
    Posts
    Global Posts
    5 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I use CoPilot and I like it a lot. It’s fast and easy to use.
  1. Nexus 5 wifi calling
    By ssrini12 in forum Google Nexus 5
    Last Post: 05-19-2015, 07:38 PM
  2. Android Smartphone without date plan?
    By DJayAce in forum General Help and How To
    Last Post: 11-19-2013, 07:05 PM
  3. Play Store & Wifi woes
    By TechZOnline in forum Google Nexus 5
    Last Post: 11-18-2013, 03:02 PM
  4. help with wifi usage.
    By Amin09 in forum General Help and How To
    Last Post: 11-17-2013, 10:25 AM
  5. is the latest BBM compatible with Nexus 7 (without using APK)?
    By gameson in forum Google Nexus 7 Tablet (2013)
    Last Post: 11-17-2013, 04:00 AM
