1. jpwoolf's Avatar
    Does anybody know if there is a way to re-install "Awsome note" back on my Samsung Note 8 ?
    I seem to have deleted it by mistake.
    Thanks for the help in advance.
    11-29-2013 02:48 PM
  2. Haalcyon's Avatar
    Welcome to the forums!
    If you look in the Play store under 'My Apps' you may see it in the list.
    11-30-2013 10:03 AM
  3. Manky Boy's Avatar
    http://www.bridworks.com/anote/eng/a...te/galaxynote/
    It says in the support section that it isn't available in the play or Samsung app stores and is only available built into the note 8. Maybe if you contact them they can point you in the right direction?
    12-07-2013 03:00 AM
  1. Samsung Galaxy S4 - Screen lock on incoming call. Help!!
    By Bob Steven Salvato in forum Samsung Galaxy S4
    Last Post: 03-02-2014, 03:08 PM
  2. Cyanogenmod on Galaxy S4? System apps?
    By Bruninho98 in forum Samsung Galaxy S4 Rooting, ROMs & Hacks
    Last Post: 12-04-2013, 07:31 PM
  3. Android 4.3 update for galaxy S3 I9300
    By Pratik7 in forum Samsung Galaxy S3
    Last Post: 12-02-2013, 12:36 AM
  4. my galaxy note 3 stuck at boot screen (Samsung logo)
    By Ghada Kholief in forum Samsung Galaxy Note 3
    Last Post: 11-30-2013, 07:44 AM
  5. Samsung Galaxy S3 - Artists disappear from artist list
    By Noelle Kahn in forum Samsung Galaxy S3
    Last Post: 11-30-2013, 05:22 AM
