Results 1 to 3 of 3
    Default How to uninstall BBM, or at least reset my pin
    Okay, I downloaded BBM onto my Note 8, and installed it. I then setup BBM using my Blackberry ID. This means I can only have BBM on my BB Z10, or my Note 8, but not both at the same time as they are using the same pin. Is there a way to release my pin in the app? If not, how does one find the app on the tablet and remove it since it did not install through the Play store, so that I can reinstall it and create a new pin.
    Thanks in advance for any help
  2. #2
    iphone5s's Avatar
    Posts
    Global Posts
    20 Global Posts
    Default Re: How to uninstall BBM, or at least reset my pin
    Quote Originally Posted by thehairlesscat View Post
    I think I understand what you're asking.
    BBM will activate by prompting you upon opening the BBM app, to activate [switch to] your BBM account on that device. No need to release the ID on the device you are not using.
    **On the Android device specifically, if you get an error message on BBM re activation then the simplest way to reactivate is to uninstall, then re install BBM.
    Your contacts will always follow to the activated device, your conversations will not.
    Yeah, I would prefer to just setup a new BBM account on the tablet I think. I don't want to lose my conversations each time. That's why I'd like to release the pin and then sign up for a new separate pin.
    You mentioned that on the androis device I could uninstall bbm. How do I do that since this device is not approved and therefore the app was downloaded directly, not through the Play Store?
  1. Moving applications to SD Card
    By tourboy in forum Samsung Galaxy S4
    Last Post: 01-01-2014, 12:31 PM
  2. Running 2 different apps at the same time???
    By jackdps in forum Google Nexus 7 Tablet (2013)
    Last Post: 12-28-2013, 01:15 PM
  3. Looking to make two tablets identical
    By mjozwiak1856 in forum General Help and How To
    Last Post: 12-27-2013, 09:29 PM
  4. Can't post photos to Facebook with ART
    By ETPhoneHomeT in forum Moto X
    Last Post: 12-27-2013, 04:12 PM
  5. Is the Galaxy Gear supposed to cut off texts and e-mails?
    By d_s_ng in forum Samsung Galaxy Gear
    Last Post: 12-27-2013, 03:43 PM
B
